Hi.
V5
having drawn a helix in a normal manner, axis start then end then type in pitch and drag to diameter required.
the result in shaded after having used pipe command, where one can see a darker line for the pipe, and certainly in wireframe shows pipe spring wireframe varying in diameter.
The spring in shaded looks ok, as does the blue original helix used.
whats going on ?
pipe variable look.3dm (1.8 MB)
Cheers
Steve
