Hi all,
I am having an issue where light is rendered with a pink hue regardless of what I do. I was hoping I could get some guidance here.
This seems to happen to other people when a environment texture is missing but in my case It happens when using anything other than an HDRI; like physical sun texture, single color, etc…
It might be important to note that this issue started when I migrated to a more capable computer, including a generous GPU. Also, this happens with existing and new files alike. I’m stumped!
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 4080 (NVidia) Memory: 16GB, Driver date: 6-8-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.23
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-8-2023
Driver Version: 31.0.15.3623
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\D5Conv (e0d5e210-02f6-4ee9-a2b0-1675e225d958)\0.12.0.0028\Rhino 8\D5Conv.rhp “D5 Sync for Rhino”
Although it shouldn’t impact the raytraced part it still is good to updated to a driver from 2024.
I checked on my M2 with an internal Rhino 8.7 build and this indeed appears to be broken. Not sure yet when this happened, it used to work. I hardly ever use physical sky texture, so it went unnoticed. Thanks for reporting. Logged as RH-81322 Physical Sky texture broken
@Diego_Fernandez_Mora , I have landed a fix for this in 8.6 service release candidate. It should go out with the next service release candidate of 8.6 at the end of the day or tomorrow.
Hi. Sorry to dredge up a resolved thread, but I am having the same issue. I have a 2020 Macbook Pro that I run rhino 8 through Bootcamp. I do this as I teach Rhino to students who are on Windows machines. I want what I am doing to be exactly what they are doing. Otherwise I would just use the mac version. Here is my system info:
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.0
Primary display and OpenGL: AMD Radeon Pro 5500M (AMD) Memory: 8GB, Driver date: 9-21-2023 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 23.9.3.230915
> Integrated accelerated graphics device with 6 adapter port(s)
- Windows Main Display attached to adapter port #1
Primary OpenGL: AMD Radeon Pro 5500M (AMD) Memory: 8GB, Driver date: 9-21-2023 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 23.9.3.230915
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 9-21-2023
Driver Version: 31.0.22011.4008
Total Video Memory: 8151 MB
C:\Users\Carter\Downloads\elefront422\elefront421\ElefrontProperties.rhp “ElefrontProperties” 1.0.0.0
C:\Program Files\Common Files\McNeel\Rhinoceros\7.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2021.3.25.899\Lumion\Rhino 7.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
Hi. I will do this in the morning. It’s my work computer and I am now at home. I did test with multiple files and even a new file. All the same. Raytrace view and render outputs.
This file works fine on the Mac side on both this computer(Intel from 2020), and my personal computer(Macbook Pro M2). But not on the Windows side of this computer(Intel).
It is according this file searched for at C:\Users\Carter\AppData\Roaming\McNeel\Rhinoceros\7.0\Localization\en-US\Render Content\Textures\RhinoSky.hdr
If it doesn’t exist maybe run a repair on your Rhino installation.
