Picture frame after drag and drop in R6 (6.4.18130.19341, 5/10/2018) does not show options for materials. Current work around is to make it a default material and then add the image in the color dialog. Any ideas?
Hmmm. thanks for the report… this works as expected here so far in the latest, I’ll test some more.
It works in 6.4 here - does this happen with any image for you?
Hello - the first thing to try is to find the latest driver for your card from the NVidia website. I don’t really think that affects the Properties but I’d still start there.
What happens if you click on that drop-down?
Howdy. Updated drivers and issue continues. No biggie, only happens when initially dragging and dropping.
Thanks for your troubles anyway.
Ah - I bet if Vray is not the current renderer, all will be as expected…
You are correct. So should I contact Vray about the transparency issue?
