Can anyone explain why the picture frame is displaying the path to the Alpha Mask in the image? How do I hide this? See red arrow pointing towards path in picture frame object.
I made this picture a week or so ago. I thought I embedded the image in the picture or at least that was my intention. I am trying to create a library of these images to use to drag and drop into equipment layout floorplans. Some, not all, of the pictures I had in the file I was working on came up with this path name inscription one day when I opened the file? If you create a picture frame and embed the file do you need the original .png file that was used to create the picture frame object? I would like to be able to pass these things around without having the original picture following it around if possible.
Hi Eric - in V5, you could embed PictureFrame images at the time the PictureFrame was created. Otherwise, they would not be embedded. In V6, the mechanism is different - Picture (new command name) images are treated just like any texture used in materials - they are saved with the 3dm file by default and if not present on the machine where the file is opened, they unpack to a separate folder and are then used from that location, but they are not embedded in the 3dm file in the same way as V5.
