Picture Bug
When inserting a picture, the new command is just ‘Picture’, not ‘PictureFrame’, correct?
If I try to insert a picture, once inserted, it’s present, but invisible. Transparency is set to 0%, but it does not show up. You can click on it, and the object becomes highlighted, as you can see the orange border and properties in the side bar, but no visible image.
Hi Ryan - wup. I see this as well in the latest - thanks for the report. OK, I see it is flipped - I think that bug is known actually, I’ll make sure its on the tracker. It should be visible from both sides of course but for now, Flip will get it back, at least from the ‘expected’ side. Does that work?
Yes, Pascal, Flip worked…
