Pick surfaces from surface component
If i have a surface component containing multiple surfaces. I want to exclude some of the surfaces and only evaluate a few of them. is there any way to do this? would it be possible to somehow manually pick some of the surfaces and send them to a new surface component?
(there are no “rule” or similarities between the surfaces i want to evaluate, so it has to be done manually and not with a cull pattern for instance)
Hi Sofie,
you can feed multiple values into the Index input of a ‘List Item’ component.
Would be one possible way to manually select objects.
