Pick data from list of points
Does anyone know how to pick out those points into the last panel?
I want to connect the red-marked points to the yellow-marked points. See attached.
Cheers.
can you upload the gh-file?
One option is to use list item and then find the index number. That could be quite time consuming though.
I would try to use deconstruct point, use the x- and y-values (that they seem to share) and then make a cull pattern from that.
Best regards
Hi again,
Thanks! Yes here is the GH-file. Please try find a solutions and then let me know.
Kind regards.
Ortofta.gh (25.2 KB)
Have a look at the attachment.
Ortofta_re.gh (16.1 KB)
Thanks. In my case my building has an extension, which you don’t include in your model.
Please, use my gh-file and show me how to connect the “missing” lines between the nodes.
Which version of Rhino and GH are you using?
Yes, it could be the reason.
I am using Rhino 5.0 and Grasshopper latest version I think.
Look here!..
Check this def. for R5.
Ortofta_reV2(R5).gh (16.2 KB)
Thanks!
MB
