Hi Cosmas- it looks like you are automatically loading a script at startup which is not designed for this- it looks to me like it would be maybe another version of ‘DetailsToolsDragNDrop.rvb’ that you have laying around someplace or indeed that script not correctly set up for drag and drop. I can take a look if you like.
That makes total sense, Pascal, because that’s exactly what DetailsTools asks for when you run it. I looked in my Scripts folder and saw that I have two versions of this:
DetailsToolsDragNDrop.rvb dated 2/22/12
and
DetailsToolsShortcut.rvb dated 3/1/14
The second one is a variation of the first one, customized by Peter Harris so that I can use an alias to quickly turn all of my details to wireframe and back (for when my drawings are slow).
Hi Cosmas - there is a line that needs to be removed or commented out - open the file in the Rhino script editor or any text editor and change the line that has
Call DetailsTools()
to
'Call DetailsTools()
(with a tick in front, to comment it out), Save the script… restart Rhino. Does that work better?
