I have this code to pick a point on a specific mesh object:
public static Point3d? GetPointOnMesh(RhinoObject obj, String message = "Select a point on mesh")
// Validate input
if (obj == null || obj.ObjectType != ObjectType.Mesh)
RhinoApp.WriteLine("Invalid mesh object.");
return null;
Mesh mesh = obj.Geometry as Mesh;
if (mesh == null)
return null;
GetObject go = new GetObject();
go.SetCommandPrompt(message);
go.GeometryFilter = ObjectType.MeshVertex;
go.AcceptNothing(true);
go.Get();
if (go.CommandResult() != Result.Success)
return null;
if (go.ObjectCount == 1)
var objClicked = go.Object(0).Object();
if (objClicked.Id != obj.Id)
RhinoApp.WriteLine("Clicked mesh is not the same mesh you clicked before.");
return null;
var pickedPoint = go.Point();
if (pickedPoint != null)
RhinoApp.WriteLine("Picked point: {0}", pickedPoint);
return pickedPoint;
else
RhinoApp.WriteLine("Failed to get a point on the mesh.");
return null;
else
return null;
I’m calling the method like this:
Point3d? point = Helper.GetPointOnMesh(inObj);
if (point.HasValue)
RhinoApp.WriteLine("Selected point: {0}", point.Value);
Question
The code works fine bu the picked point is too large:
check the result you get from GetResult result = go.Get();
it should be
GetResult.Point
You can also / additionally check for Point3d.Unset, instead of checking for null
