Here’s an object which doesn’t display, but it prints. It’s on the same layer as other entities which both display and print. It’s Text. Close/Reopen fixed it.
I’m guessing here… but I’m suspicious (/curious) about this text object being placed on a layer that’s using a DashDot line type.
What happens if you set a new line type to this layer?
Thanks Jim. I thought the same, so even though it’d been displaying fine for hours up until the corruption, I set its linetype to continuous, but that didn’t correct the problem. (The other settings are visible in the o.p. as well.)
It’s corrected for the time being but I’ll experiment more if it happens again - maybe put it on another layer. Of course, the label for a Grid line is handy to have on the same layer as a grid line…
