PgUp/Down nudging not working
In the current WIP there’s something still going on with pageup/down nudging. It doesn’t work at all or only works once, it’s a bit odd…
How do you have your nudge set up? Alt+ arrow keys or just the arrow keys?
So far both seem to work properly here, but Shift+PageUp/PageDown is still assigned in Keyboard shortcuts, so if you use the latter, these need to be removed first.
Just the arrow keys, as it should be.
Nothing is assigned in the keyboard shortcuts.
It’ll work like once and then not until something happens…
just to be sure:
so your arrow keys work normally,
PageUp/Down work sporadically
Same for Shift and Ctrl + PageUp/PageDown?
So far I don’t see anything weird here. Does that happen right after you fire up Rhino?
Just checked on the very latest WIP…
Yes the arrow keys are normal.
PageUp/Down with any modifiers works only sporadically.
On a bare new file they seem to work fine??
The file I notice it on doesn’t use the standard 4 viewports.
something you could share?
Not publicly, will send…
Hi Jim, Thanks for reporting RH-91704 Nudge fails on objects with history
