Perspective Match Plugin
But is it REALLY any better than PerspectiveMatch? :thinking:
Jokes aside, that look really neat! Well done!
-Jakob
PerspectiveMatch requires 3d model with known dimensions
Hi @seg
I was just kidding! The native Rhino PerspectiveMatch command has been somewhat of a joke since, well, forever. What you have there looks really great and impressive compared to the existing command :slight_smile:
-Jakob
Rhino native command is very useful when we need place a real model, but it is limited
Hi seg
This perspective-matching plugin looks very interesting. Is it a paid plugin, or is it already available for public download?
Thanks!
His plugins are typically available on f4r and the package manager. I don’t recall any of them being pay-to-play, although there is a buy-me-a-coffee link.
https://www.food4rhino.com/en/app/rhino-gaussian-splatting
As Japhy said , it is free and i will publish it to foo4rhino soon
Thank you @Japhy
Testing the recreation of a Rhino model with the plugin. The result is accurate.
The plugin available in food4rhino:
https://www.food4rhino.com/en/app/rhino-photo-match
Buy me a coffee link:
Rectify restores the natural 3-point perspective tilt to photos whose vertical lines were artificially straightened.
Why is it needed?
  1. Architectural Photography & Tilt-Shift: Architectural photographers often use tilt-shift lenses, Photoshop perspective correction, or 2-point perspective render cameras to make building vertical edges strictly parallel (90∘90^\circ90∘ to the horizon).
  2. The 3D Solver Problem: In a real 3D camera, tilting up or down physically causes vertical lines to converge toward a 3rd vanishing point (ZZZ). When a photo’s verticals have been artificially flattened to parallel, a standard camera solver cannot physically reconcile the camera tilt with parallel lines, resulting in focal length distortion or blue ZZZ-axis mismatch.
Does it also work on cropped images?
If you have one send me to test it
Thanks, @seg will definitely check this out!
Control Principal point added to fix perspective in case of cropped image
on food4rhino you mark it as Windows only - I just try it on a mac with the actual WIP - No Problems at all :slight_smile: Thanks for the very useful PlugIn
Yes it built to work in mac too but since i don’t use it i can’t confirm.
Thank for testing it in macOs.
will this work with Rhino 7? plugin looks awesome!
For now Rhino 8 and Rhino 9
  1. Default camera: Principal Point is in the image center (50%,50%)
  2. To fix vertical lines: Principal Point simply sits on the horizon (50%,yhorizon)
Updated to V1.2.0
