Hi. Could it be possible to remove the persistent R shortcut that starts Rhino.Inside?
Currently it rewrites itself on every Revit restart.
@JC60 I believe you can remove it from the shortcut keys options in revit.
Unfortunately it is persistent. Removing it will only last for 1 Revit session.
@kike can help in this regard.
I tested it and it is a bug.
Unfortunately there is no current way to delete the accelerator.
I will fix this in 1.36.
Meanwhile if you want to assign R to another command you can just assign any other keyboard combination to RiR Start command.
