Persistent Publishing Path
It would be great if the Print Dialog would remember the pathway/filename used last time. As it is now, if the PDF (for example) is to end up somewhere else and with a different name than the filename, one has to retype (and find folder) every time. This becomes quite tedious …
For the layout, each layout should have a stored path + filename. Thus it becomes simple to publish PDFs in a structured way.
Thanks
