Persistent id on topology?
does Rhino save persistent ids on the faces and the edges of breps ? If yes, please where can I find them with opennurbs ?
Regards.
Hi @jerome.roche,
No it does not. Why do you need this? What programming language are you working in?
– Dale
Hi Dale,
I import a 3dm brep and attach some information on some faces or edges. If the 3dm brep changes and if I import the changed version, I want to be able to recognize the faces or edges I previously imported.
I am using C++ programming language.
When working with the history activated, does not Rhino keep a track on the topology ?
Please what is the purpose of the following lines in opennurbs_brep.h ?
// Persistent id for this face. Default is ON_nil_uuid.
ON_UUID m_face_uuid = ON_nil_uuid;
Thank you for your answer.
Hi @jerome.roche,
Thanks for reminding me about ON_BrepEdge::m_face_uuid, I had forgotten we had added that. Sure, you can use that to track faces. There isn’t an equivalent on ON_BrepEdge. To track edges, you might consider adding either user text or user data to the edges underlying 3D curve, or ON_Brep::m_C. You can do something similar to faces if you choose not to use m_face_uuid. Here is an example:
/cmdSampleBrepFaceUserData.cpp
– Dale
Hi Dale,
why did you add ON_BrepFace::m_face_uuid ? Is there a way to make Rhino set ON_BrepFace::m_face_uuid in 3dm files, without developping a custom command ?
Thank you for your answers.
No, there is not.
– Dale
