I am now using an input to where I stick the menu selection to Persistent Data and recall Persistent Data using the following method:
class MyComponent(component):
def __init__(self):
self.Component = ghenv.Component
pp = self.Component.Params.Input[3]
try:
self.typ = pp.PersistentData[0][0].Value #Gets internal Value
except:
self.typ = 0
def RunScript()......
#Edited StateChange to store Persistent Data
def StateChange(self, obj, args, typ):
#Create or modify the Persistent Data
pp.PersistentData.ClearData()
pp.PersistentData.Append(gh.Types.GH_Integer(typ))
self.typ = typ
ghenv.Component.ExpireSolution(True)
This works well, however I wish to remove to hide the input so the user uses the internal menu to change the state of the component. Is there a way to store persistent data to some internal param, rather then then using an input for it?
Found this thread regarding a similar issue, it looks like read()/write() methods are the way to go. @piac
