Perpendicularity
I connect a curve setting it as such to the input of the python component and using the ExtremeParameters method I get the quad points of the same.
sorry for the “perhaps useless” question:
is there a method analogous to ExtremeParameters which reports the perpendicularity between the tangency t value of the curve and the vector on it of a specific point?
You can calculate the angle between the vectors and if that is 90 degrees, the vectors are perpendicular
There’s also the Vector3d.IsPerpendicularTo method.
thanks @martinsiegrist @AndersDeleuran for the replies
I know this method, but with Vector3d.IsPerpendicularTo I go to “check” if two vectors are perpendicular, while with ExtremeParameters it automatically finds the perpedicularity between the tangency and the axis indicated on the domain of a curve.
who knows maybe the ExtremeParameters code checks only if the tangency has a value of 1 and consequently the vector of the indicated axis must necessarily be perpendicular.
I guess if a method were feasible where you indicate curve and point and return all perpendicular points of the curve from the indicated point, they would. . . .
