Hi!
I’ve tried to resolve this problem, but I can’t find the way for this.
I need to get a central axis by each arm and generate perp planes, which perp planes following those central lines.
I upload a example photo.
Thank you for your help!
Arms.gh (8.1 KB) Arms.3dm (690.9 KB)
“brebs” indeed. This is a silly and desperate effort since these aren’t true centerlines at all. There are some parameter tweaks that make it work better (or worse). Probably useless.
Arms_2020Sep24b.gh (16.9 KB)
Taking it one step further… The centroids of the “approximate” sections (version ‘b’ in previous post) are used to create a new centerline that is much closer to true?
Arms_2020Sep24c.gh (23.9 KB)
One mesh has a gaping hole (missing face?) that breaks the cross-sections, shortening the loft result:
Arms_2020Sep25a.gh (101.4 KB)
Meshes are internalized, no need for Rhino file.
Hi Joseph! it seems to be very usefull
Actually as you can see I’m a beginner, and every contribution you have made has help me so much.
Thank you for your time!
