Permanently delete material
I try delete material on document:
            var textures = doc.Materials;
            foreach (var item in textures)
                doc.Materials.Delete(item);
this does not permanently erase, when the .3dm file is opened again on another pc, all textures will be created from the embedded folder again.
I need delete permanently from document.
Thanks
You need to remove also all materials from RenderMaterials table:
import scriptcontext as sc
mats = [mat for mat in sc.doc.Materials]
for mat in mats:
    sc.doc.Materials.Remove(mat)
rms = [rm for rm in sc.doc.RenderMaterials]
for rm in rms:
    sc.doc.RenderMaterials.Remove(rm)
Thank you @nathanletwory
Another question @nathanletwory
how can I ckeck if the material is being used?
Iā€™d go over objects in document, get Id from RenderMaterial assigned to each object. Create also set with Id's of all RenderMaterials.
Here a sample script that shows one way of using sets to figure out what materials are used, what not.
# sets to play with
all_mats = set([rm.Id for rm in sc.doc.RenderMaterials])
used_mats = set([o.RenderMaterial.Id for o in sc.doc.Objects if o.RenderMaterial])
unused_mats = all_mats - used_mats
print(len(all_mats), all_mats)
print(len(used_mats), used_mats)
print(len(unused_mats), unused_mats)
# for comparison now remove all material assignments and rerun used mats and
# unused mats sets
for o in sc.doc.Objects:
    if o.RenderMaterial:
        o.Attributes.MaterialIndex = -1
        o.CommitChanges()
sc.doc.Views.Redraw()
thank you @nathanletwory
