I am relatively new in grasshopper development. I was developing a component with persistent data and realised that if I instantiate another componet with the similar inputs the default output value from the new component is taken from the old component.
Let me illustrate with an example.
I have created a component where it computes a simple addition of two numbers when a button is clicked ; also it resets the value if a reset button is clicked. but once the data is computed, and I put another component (red group) in the canvas and fed in all the input parameter by default it shows the value from th previous compoent ( white group).
What steps can be taken to avoid this scenario ? I want to instantiate multiple similar component without this problem / issue.
This is the code I have used for the component
using Grasshopper;
using Grasshopper.Kernel;
using Rhino.Geometry;
using System;
using System.Collections.Generic;
namespace PersistentData
public class PersistentDataComponent : GH_Component
private static double _addition; // persistent variable to store addition
/// <summary>
/// Each implementation of GH_Component must provide a public
/// constructor without any arguments.
/// Category represents the Tab in which the component will appear,
/// Subcategory the panel. If you use non-existing tab or panel names,
/// new tabs/panels will automatically be created.
/// </summary>
public PersistentDataComponent()
: base("PersistentData", "PD",
"This components adds and clears two numbers on command",
"AD_TEST", "Core")
/// <summary>
/// Registers all the input parameters for this component.
/// </summary>
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
pManager.AddBooleanParameter("Reset", "R", "Reset the Addition", GH_ParamAccess.item);
pManager.AddBooleanParameter("Compute", "C", "Compute the Addition", GH_ParamAccess.item);
pManager.AddNumberParameter("A", "A", "Component A", GH_ParamAccess.item);
pManager.AddNumberParameter("B", "B", "Component B", GH_ParamAccess.item);
/// <summary>
/// Registers all the output parameters for this component.
/// </summary>
protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
pManager.AddNumberParameter("Result", "R", "Addition Result", GH_ParamAccess.item);
/// <summary>
/// This is the method that actually does the work.
/// </summary>
/// <param name="DA">The DA object can be used to retrieve data from input parameters and
/// to store data in output parameters.</param>
protected override void SolveInstance(IGH_DataAccess DA)
bool reset = false;
bool compute = false;
double a = double.NaN;
double b = double.NaN;
DA.GetData(0, ref reset);
DA.GetData(1, ref compute);
DA.GetData(2, ref a);
DA.GetData(3, ref b);
if (reset)
_addition = 0;
if (compute)
_addition = a + b;
DA.SetData(0, _addition);
/// <summary>
/// Provides an Icon for every component that will be visible in the User Interface.
/// Icons need to be 24x24 pixels.
/// You can add image files to your project resources and access them like this:
/// return Resources.IconForThisComponent;
/// </summary>
protected override System.Drawing.Bitmap Icon => null;
/// <summary>
/// Each component must have a unique Guid to identify it.
/// It is vital this Guid doesn't change otherwise old ghx files
/// that use the old ID will partially fail during loading.
/// </summary>
public override Guid ComponentGuid => new Guid("04F9D727-C988-412E-B045-27A65A89D957");
