till now there are many threads about performance issues. The VA team deals with Many of them (or all of them), and provides fixes, RC or even official updates. Overall, in my opinion there is a significant mismatch between what the computer specs can provide in terms of performance and what the Rhino and VA can handle and how fast. In other words, I believe that in simple tasks, Rhino and VA could improve in terms of performance.
The file I am working with is: 236 MB, attached in a worksession file, containing other files including two 5GB point cloud files (.3dm). The point clouds are not visible in the viewport. When I try to update the vaplans, it takes ages. When opening the .rws it takes ages. When I try to move layers up and down - pretty standard when trying to get things clean - it has serious lags.
I am curious, if the point clouds are not visible, are they taken in calculations of the VAplans and VAsections? Is this related to a previous - fixed with the RC - thing about calculating non visible worksessions files’ elements, such as guides? Should worksession elements calculated in VAplans or not?
I’ve tested in the laptop that I am currently working, RTX4070 with low ram and in the desktop with ram ~32GB. I am not posting all the specs here. The layers movement, has been tested with similar performance without 5GB point clouds too.
If it’s about computer specs, can you give us officially the recommended setup? If it’s about configuration, can you give us the recommended one? Do you think that you can provide improvements in the near future, maybe in collaboration with Mcneel? Because for sure, there are performance factors related to Mcneel itself.
Fellow architects, work with similar computer specs, with 500MB files in Archicad, Sketchup etc, with a slighly higher performance I must say.
Have you as VA dev team found things that can be improved?
Thanks in advance.
I forgot to mention Autosave..
I forgot to mention changing a layer in the wall style attributes…
I forgot to mention: orbiting in perspective mode, while having 2d drawings in the file (exploded vaplans or vasections)
