Perforate Surface Using Image Sample Issue- "Circle Cannot Be Extruded"
Hello! I am having an issue trying to extrude circles through a surface, I am wanting the circles from the image I am using to cut through the surface that I have made. So far the circles are showing up as if they are “laying” on the surface as lines, but the extrude command is giving me the error: “Circle Cannot Be Extruded”.
Circle Perf Pattern.gh (538.6 KB)
I can’t seem to be able to download that file, but given this :
I think you are looking for Surface Split instead of extrusion ?
You could also Merge the rectangle and the circles and use Boundary Surfaces directly.
That’s strange! I just downloaded the grasshopper file using the link I put in the post and it worked fine so I’m not sure what’s going on :frowning:
How would I merge the rectangle (surface) and the circles? Forgive my ignorance I haven’t used Grasshopper much haha
Use Merge ! :smiley:
The Boundary Surfaces method only works is the circles are inside the rectangle, but this seems to be the case in your example.
I don’t know what’s happening, Firefox throws a nasty PR_CONNECT_RESET_ERROR.
Thanks! I’ll try that and report back!
