Hello everyone i am just struggling a bit maybe you guys could give me a hint on how to approach this…
So my goal would to creat a grid of cells that have 63% of the area of the surface they were created on
the top square i draw everything by hand and now i would like to be able to adjust the size of the cells but for them to always keep 63% Area of the surface they lay on
And specify the number of rows? Otherwise you get all narrow cells that are full height.
As @maje90 asked, what about vertical spacing or distance from top and bottom surface edges?
Incomplete spec…
P.S. Here is a thing that demonstrates flaws in this spec, and some ways of thinking about it.
As you can see, spacing is an issue. If ‘Clearance_H’ is zero, the cell widths consume the full horizontal distance with nothing left for gaps. If ‘Clearance_H’ is too large, the cells may not fit within the original surface. Vertical spacing can be derived but I can’t be bothered.
