Is it possible with Rhino Inside to create a door family including the possibility of adjusting a percentage of opening in a property defined by an opening angle between the frame and the opening ?
Using Grasshopper you can do that.
I know we can do it with Grasshopper / Rhino or VisualARQ but I would like to be able to do it with Rhino Inside components so that the door can open in REVIT via an opening angle property setting
https://www.rhino3d.com/inside
What I can understand is that you can use Grasshopper Rhino Inside. Rhino Inside components includes Grasshopper.
But exactly how, I’m not able to help you here.
Yes, it’s Rhino inside technology that I want to use. The documentation can be found at the following link: https://www.rhino3d.com/inside
This is similar to
