Aha.
That explains why PRINTING from Illustrator through PDF995 produces clean curves.
I assume this converting to lines is done for all printing jobs in Rhino.
No wonder then that the output is lines.
Question:
To get PDFs with curves from Rhino, there must be something different then the current print mechanism.
Is this what ‘Save as PDF’ is intended for?
Would improvement mean a rewrite of the curve conversion?
In addition I want to note that PDF can (and is) also used for production purposes, so a clean as possible output is paramount (IMO) That was my reason to pursue an automated method for clean PDF output as posted here:
There’s no doubt that the traditional arrangement of the layout function being essentially a ‘window’ on to the model space as it is in Rhino and AutoCAD is better than layout being a separate application like it is with SU / LO. But I have gotten a sense of why some people over there are excited by LO - it functions for them like a mini Illustrator in 3D space (I’m aware I’m stretching an analogy by comparing LO to Illustrator). Nonetheless, when I have to make the trip from Rhino to LO it’s tedious and cumbersome and I look forward to a time when I won’t have to.
I think this is important in more ways than the narrow question of PDF quality. I’ve found that my clients are jaded by renderings - i.e. the full blown, photorealistic images generated out of V-Ray and Maxwell and, I assume, Brasil. They’ve seen it all and aren’t impressed. I’m starting to look at more graphically complex presentations that combine technical data with images and text and so on. I think that’s the way forward now and I think Rhino, if it can upgrade it’s PDF and vector capabilities is ideally situated to offer that kind of output. Imagine a kind of Illustrator overlay in layout that would allow for a more advanced manipulation of images without having to go outside of the Rhino environment …
Save as PDF is there primarily because there were several users that didn’t realize they could use the print command to generate a PDF. Save As PDF pretty much just runs the print command with a PDF printer set as the default.
There is no current mechanism for getting curves directly into PDFs from Rhino (without going through some intermediate step like saving to AI.) This is new code that we will have to write.
Yep. We would need to fit NURBS curves to what is available in the PDF file format; that would be two dimensional arcs, polylines (what we currently do), and cubic beziers.
I don’t see us getting much more accurate on our PDF output by changing our process. If we start fitting 2D simple beziers to our curves for output there will be a fitting algorithm involved and that fitting will need to be performed to some level tolerance. Of course lines are also a fit approximation of the curve, and those line segments are within the distance of a dot on the PDF (typically somewhere around 600DPI.)
Technically you are right, the output will allways - just like it is now- be withing a set tolerance. However, quality of curves cannot be measured just by the deviation amount. I was referring to how clean the curves could be. The current setup does not produce smooth or clean curves by design, although the polylines are within tolerance, they can be quite jagged in appearance. If a conversion to beziers is implemented the appearance will no doubt improve dramatically overall, (as will the filesize reduction I suspect).
In any case, I expect the output to be with more fidelity as for instance small circles and acrs will be converted without much loss of accuracy.
One great advantage of a vector format is the lack of resolution restrictions; one can zoom in and out without a “loss of focus” (for lack better words). The current polyline conversion sort of introduces a pixel type resolution within a vector format, making the output loose that scale-ability advantage of vector files.
Thinking about that, it might be good to differentiate between PDF purposes. Where the user can export to PDF and have an option to choose a fidelity/tolerance. That way we can produce a letter format page of a building site to be easily printed on paper for reference, yet with high accuracy for onscreen review, zooming in to the smallest details.
What would be needed is an option to let the user set the absolute tolerance with which the fitting algorithm operates. Minimal tolerance would be the absolute file tolerance, producing a PDF with curves that are most accurate to the ones in the Rhino document, regardless of the PDF page size. Maximum tolerance would be based on the desired DPI for print with that page size.
I do not know how this would be best implemented with the correct wording and GUI, to make it as unambiguous as possible.
Maybe a few presets or slider for various DPI’s and an overriding checkbox to use file tolerance?
Anyway so far my2c and brainstorm on this
Thanks,
-Willem
+1 on wishing we could get much better quality lines printed in PDF format.
Clients don’t understand or care why it’s a problem to do it from Rhino. To them it’s a sign that you cannot do something that ‘ought’ to be (in their minds) simple.
By “sending to PDF” do you mean Printing with a PDF printer?
If so then you are affected by the printersettings and need to set the PDF printer to high quality.
It’s the quality of the Rhino output of curves that I’m concerned about (i.e. not curved curves, but all straight lines - thousands of them), as discussed earlier in the thread. I’m creating a lot of ‘print ready’ artwork in Rhino atm and it’s a real pain having to export as .ai as well as printing to PDF; the former to provide the vector artwork, the latter to give a visual guide to the Printer as the fills in the .ai files are often well out of whack.
If I buy/install a full version of Adobe Acrobat, will the printer driver it incorporates allow me to print clean curves direct to PDF?
Rhino’s PDF output goes through a PDF printer driver and is really optimized for directly printing to paper. We do hope to eventually produce cleaner output since we know that people aren’t necessarily printing their PDFs to paper and the pdf may be edited more in applications like AI or zoomed in very close when viewed.
Unfortunately this is a big project, so you won’t see any improvements in this area for V5
Which is fine as far as it goes and it’s why I send the artwork to the Printers in that format, but I’m making hundreds of files. There are also people involved in the approvals process that don’t have Illustrator or similar (neither do I for that matter) and for them, PDF is by far the preferred option.
I’m also find I’m getting comment from the Printer that the more complex fills (which are created from Rhino solid hatching) sometimes do very strange things. If I import the .ai files back into Rhino, I too see the errors. This doesn’t happen when I print to PDF - what I see on screen is what I get, aside from the nuances of setting up print colours to be different to the display colour to get over the fact that I work on dark grey viewport backgrounds. But that’s all in my control. ‘Print Ready’ PDFs aren’t
So I’ll just request that this isn’t forgotten about. I consider it a very important feature and would put it pretty high up my wish list. DennyM’s comment is how I feel - others involved in creating the print artwork think I’m using ancient software because it creates rubbish PDFs!
This is just an annual bump of the topic in the forlorn hope that it isn’t forgotten about. As the Illustrator 8.0 format becomes more and more ancient, the ability to output smooth clean geometry as PDF files and not something that looks like the back of a Stegosaurus becomes more and more relevant. @stevebaer made comment on this thread in early 2014 that it is something that’s on Mcneel’s radar. That was nearly 3 years ago. I’m now getting instances where co-workers can’t open Illustrator 8 format as their own software has been updated and doesn’t support it any longer.
I wonder if an investment in svg export would not be better. If I’m not mistaken, illustrator can read those without much problems. And the format is supported by a wide range of software.
