Hi V8
Import a plan from FH10 as a .pdf, comes in on ‘default’ layer.
see orange station lines, black outline of aircraft etc.
need lines a bit thicker, select line thickness for default layer, and alter to a size near base of the chart of 1.2, and all lines go black.
I wanted to alter thickness not colour.
What is going on ?
unusable.
FH10 is Macromedia Freehand 10
FH number was the way Freehand was referred to. until it became MX
FH7 FH9 etc.
Far better than iIlustrator, but Adobe killed it reckoning theirs was better when they purchased Macromedia.
I expect to alter the line weight and still see orange lines, not have them turn black.
I alter weight, then turn on printPreview to see the weight, and they go black.
While you have the objects’ display colour set to orange you have their print colour set to “By layer” and the layer print colour is black. By turning on Print Preview you see the print colours instead of the display colours.
This has nothing to do with the lines coming from a pdf file. Rhino is just showing you what you’ve set it up to do.
