PDF Export Misses Data from Top view?
I’m trying to use Rhino to be able to export certain parts of my document as Orhtographic PDFs.
This is the file I’m having trouble with.
PDFProblem.3dm (915.6 KB)
  1. I select the objects in the scene (its part of a bigger project but I isolated the problem to this).
  2. File->Export Selected -> PDF
In “Vector Output” mode, it looks ok, but no texture (which is expected):
In “Raster Output” mode, from Top view, I see nothing (which is what I want help with):
In “Raster Output” mode, from Perspective view, I see the objects (but the result does not look like I want it to)
Is this expected behavior? Am I doing something wrong?
Hello - as far as I can see this works here in Top - does this look like what you are after?
PDFProblem.pdf (237.3 KB)
Please run the SystemInfo command in Rhino and copy/paste the results here.
Pascal
Did you achieve this output using Raster Output + Top + Extents configuration?
Here are is the output:
Rhino 6 SR28 2020-7-17 (Rhino 6, 6.28.20199.17141, Git hash:master @ b1f15b655bd1f5ae0d3d3257e3efdeb0a45630e4)
License type: Evaluation, build 2020-07-17
License details: Stand-Alone
Expires on: 2020-10-06
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: MACK
Non-hybrid graphics.
Primary display and OpenGL: NVIDIA GeForce GTX 1060 6GB (NVidia) Memory: 6GB, Driver date: 11-6-2019 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 441.20
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-6-2019
Driver Version: 26.21.14.4120
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.28.20199.17141
C:\Program Files\Rhino 6\Plug-ins\Export_FBX.rhp “Export_FBX”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\Iris (1cd9c8f5-c901-426c-8e80-d6a2e2b18bba)\1.0.7284.18297\Iris.WinR6.rhp “Iris” 1.0.0.0
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.28.20199.17141
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.28.20199.17141
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.28.20199.17141
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.28.20199.17141
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.28.20199.17141
Hello - thanks, I see the ‘extents’ problem now.
RH-60027 Print: Raster and Extents show a blank print
Thanks for the professional response! Will keep an eye out for the issue on the tracker.
