PDF Export Encoding Shapediver
I would like to include the Hungarian letters in my pdf. How can I set the encoding behind the shapediver Pdf output (utf-8)?
Képernyőkép 2023-12-04 132210
You can use the Font component of the Squid plugin to define the font used for drawing text with the Text component. Of course, the font you specify needs to be installed on our servers.
Note that the Write PDF component can only be used to export and test locally. If you want to include a PDF output in your ShapeDiver model, you need to use the Download Export component for example.
