Hi. I have a Python script to export a Rhino layout to PDF.
In the script, I add some text to PDF page.
It works fine in Rhino7 both with alphabet and with Japanese font.
However, in Rhino8 Japanese text is ignored while English one comes out as is.
In Rhino7:
In Rhino8:
If I place a Japanese text object in the layout, it is exported properly.
That is to say, font is not the problem and issue seems to be in PDF creation in Python.
Here is my code.
You can test with Rhino 3dm which has A3 size layout named “Main Layout”
# -*- coding: utf-8 -*-
# RhinoPythonコードを使用してレイアウトのPDFファイルをエクスポートする
import Rhino
import System.Drawing
import scriptcontext as sc
# レイアウトをPDFとしてエクスポートする関数
def export_layout_as_pdf(layout_name, file_path, dpi=300):
# レイアウトを取得
layout = sc.doc.Views.Find(layout_name, False)
if layout is None:
print("指定されたレイアウトが見つかりません: " + layout_name)
return
# PDFファイルを作成
pdf = Rhino.FileIO.FilePdf.Create()
size = System.Drawing.Size(16.53 * dpi, 11.69 * dpi) # A3サイズ
# レイアウトの設定
view_settings = Rhino.Display.ViewCaptureSettings(layout, size, dpi)
view_settings.RasterMode = True
view_settings.OutputColor = Rhino.Display.ViewCaptureSettings.ColorMode.DisplayColor
# PDFにページを追加
pdf.AddPage(view_settings)
text_font = Rhino.DocObjects.Font("Meiryo")
text_holizontal_alignment = Rhino.DocObjects.TextHorizontalAlignment(1)
text_display_alignment = Rhino.DocObjects.TextVerticalAlignment(4)
clr = rs.CreateColor(0,0,0)
pdf.DrawText(
1, "ENGLISH 日本語", 16.53*dpi/2, 11.69*dpi*(92/100), 36, text_font,
clr, clr, 0, 0, text_holizontal_alignment,
# PDFファイルを書き出し
pdf.Write(file_path)
print("PDFがエクスポートされました: " + file_path)
# 使用例
export_layout_as_pdf("Main Layout", "C:/Users/vicc_ishihara/Desktop/output.pdf")
