I’m taking V7 for a spin and seeing if some of my V6 issues will go away with it.
I do a lot of PDF generating. This is a sample command:
using System;
using System.IO;
using System.Linq;
using Rhino;
using Rhino.Commands;
using Rhino.Display;
using Rhino.DocObjects;
using Rhino.Geometry;
namespace Dev.Common
System.Runtime.InteropServices.Guid("726ced4a-8585-4a66-9a3c-da1964808c58"),
CommandStyle(Style.ScriptRunner)
public class PdfCommand : Command
public PdfCommand()
// Rhino only creates one instance of each command class defined in a
// plug-in, so it is safe to store a refence in a static property.
Instance = this;
///<summary>The only instance of this command.</summary>
public static PdfCommand Instance { get; private set; }
public override string EnglishName => "PdfCommand";
protected override Result RunCommand(Rhino.RhinoDoc doc, RunMode mode)
try
GeneratePDF.DoStuff(doc);
RhinoApp.WriteLine("Done");
return Result.Success;
} catch (NullReferenceException exception)
Console.WriteLine(exception);
RhinoApp.WriteLine("Failed");
return Result.Failure;
public static class GeneratePDF
public static void DoStuff(RhinoDoc doc)
// Using RhinoScript since ViewTable.AddPageView also doesn't work in V7
string createPage = $"_-Layout \"foo\" 297 210 0 _Enter";
RhinoApp.RunScript(createPage, false);
var pageView = doc.Views.GetPageViews().Last();
var detailView = pageView.AddDetailView("bar",
new Point2d(0, 0),
new Point2d(100, 100),
DefinedViewportProjection.Perspective
// This is the offending line. Comment this out, and it will work.
// DisplayMode isn't null after this line.
// Doesn't fail before AddPage(..) further down is called.
detailView.Viewport.DisplayMode = DisplayModeDescription.FindByName("Technical");
detailView.Viewport.Rotate(Math.PI, detailView.Viewport.CameraY, new Point3d(1, 1, 1));
detailView.CommitViewportChanges();
detailView.CommitChanges();
var sheetPdf = Rhino.FileIO.FilePdf.Create();
var sheetCapture = new Rhino.Display.ViewCaptureSettings(pageView, 300);
// This will fail:
sheetPdf.AddPage(sheetCapture);
string partPdfPath = Path.Combine(Path.GetTempPath(), $"{Guid.NewGuid()}.pdf");
sheetPdf.Write(partPdfPath);
Running that will fail in the AddPage line marked above.
The NullReferenceException looks like this:
"Object reference not set to an instance of an object"
"System.Drawing"
" at System.Drawing.Bitmap.InternalSave (System.String path, System.Drawing.Imaging.ImageFormat format) [0x000bc] in <2b335274651f4b938bfc96d92815357e>:0
at (wrapper remoting-invoke-with-check) System.Drawing.Bitmap.InternalSave(string,System.Drawing.Imaging.ImageFormat)
at System.Drawing.Image.Save (System.String filename, System.Drawing.Imaging.ImageFormat format) [0x0000a] in <2b335274651f4b938bfc96d92815357e>:0
at System.Drawing.Bitmap.InternalSave (System.String path) [0x00086] in <2b335274651f4b938bfc96d92815357e>:0
at (wrapper remoting-invoke-with-check) System.Drawing.Bitmap.InternalSave(string)
at System.Drawing.Image.Save (System.String filename) [0x0000a] in <2b335274651f4b938bfc96d92815357e>:0
at (wrapper remoting-invoke-with-check) System.Drawing.Image.Save(string)
at ExportPDF.PdfPageWriter.DrawBitmap (System.Drawing.Bitmap bitmap, System.Double m11, System.Double m12, System.Double m21, System.Double m22, System.Double dx, System.Double dy) [0x0005c] in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/rhino4/Plug-ins/export_PDF/ExportPDFPlugIn.cs:289
at Rhino.Runtime.ViewCaptureWriter.TexturedPlane (System.IntPtr pRhinoDibOrNsImage, System.Double m11, System.Double m12, System.Double m21, System.Double m22, System.Double dx, System.Double dy) [0x000ca] in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/DotNetSDK/rhinocommon/dotnet/rhino/rhinosdkprintinfo.cs:1428
at (wrapper native-to-managed) Rhino.Runtime.ViewCaptureWriter.TexturedPlane(intptr,double,double,double,double,double,double)
at (wrapper managed-to-native) UnsafeNativeMethods.CRhinoPrintInfo_VectorCapture(intptr,Rhino.Runtime.ViewCaptureWriter/SetClipRectProc,Rhino.Runtime.ViewCaptureWriter/FillProc,Rhino.Runtime.ViewCaptureWriter/VectorPolylineProc,Rhino.Runtime.ViewCaptureWriter/VectorArcProc,Rhino.Runtime.ViewCaptureWriter/VectorStringProc,Rhino.Runtime.ViewCaptureWriter/VectorPolylineProc,Rhino.Runtime.ViewCaptureWriter/VectorFillPolygonProc,Rhino.Runtime.ViewCaptureWriter/VectorPathProc,Rhino.Runtime.ViewCaptureWriter/VectorPointProc,Rhino.Runtime.ViewCaptureWriter/VectorBitmapProc,Rhino.Runtime.ViewCaptureWriter/VectorRoundedRectProc,Rhino.Runtime.ViewCaptureWriter/VectorClipPathProc,Rhino.Runtime.ViewCaptureWriter/VectorGradientProc,uint)
at Rhino.Runtime.ViewCaptureWriter.Draw (System.IntPtr constPtrPrintInfo, Rhino.RhinoDoc doc) [0x00177] in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/DotNetSDK/rhinocommon/dotnet/rhino/rhinosdkprintinfo.cs:971
at ExportPDF.PdfDocumentWriter.AddPage (Rhino.Display.ViewCaptureSettings settings) [0x001aa] in /Users/bozo/TeamCity/buildAgent/work/96e64af5b81c6f85/src4/rhino4/Plug-ins/export_PDF/ExportPDFPlugIn.cs:847
at Stykka.Common.Views.ProjLayout.GeneratePDF (Stykka.Common.Part part, Rhino.RhinoDoc doc, Rhino.Display.RhinoPageView& pageView, Rhino.DocObjects.DetailViewObject& orthoDetailView) [0x0004c] in /Users/aske/Projects/Stykka/Stykka.Common/Views/MyLayout.cs:678
Since I don’t provide a Bitmap at any point I assume this is somewhere in the application code.
System:
Version 7 BETA (7.0.20273.15004, 2020-09-29)
Mac OS X 10.14.6
I didn’t “upgrade” my application code in any way from V6. I just changed target and then it worked. Is there anything else I should do?
Thanks,
Aske
