PBR texture in shapediver
is it possible to use a PBR texture in shapediver with all the settings from several image textures (normal, height map, rugosity etc… ?
Use the ShapeDiver advanced material which allows image inputs via URL for most of the properties (texture, metalness, roughness, bump map, normal map, opacity).
Learn more about texture mapping from following resources:
