Hi, is there a way to directly import materials from https://cc0textures.com ?
Or, do I have to create my own PBR materials from those files ?
Unzip the files into a folder, then use import PBR texture files…
See this thread here:
You should be able to drop the ZIP file directly on Rhino even - on an object or into the materials panel.
In the first 15 seconds of the video below I drag a ZIP file from Brick Wall 001 Texture • Poly Haven containing all the texture maps onto the materials panel:
Thank you
First time I succeed importing a Substance 3D Sampler material without exploding faces of the object
I saved each layer in a zip file .
