I wanted to play around with the new PBR capabilities of the WIP, but Rhino consistently crashes when I try to create a new PBR Material with the Create from texture files...
Option. I send the crash report the first two times, so you can also find it in your system.
This seems to be related to either the File-size or the amount of files i give, see:
When I use all files, Rhino crashes 100%, when I use a random differing subset (without the largest .exr file) Rhino crashes on some combination of files, while others succeed. This is of course not desirable as I’m losing information when I can’t import all files.
I could upload the texture files in question if given a link, but I don’t know who is working on the PBR Implementation, is it @scottd?
