Hi. Every time I try to use the pave feature in CrossGems, it crashes Rhino (I’m using Rhino 7 and the latest version of CG). Has anyone else had this issue? If so, how did you correct it?
Thanks~ I appreciate your time and input.
Hello Teresa,
Could you run the command _SystemInfo in the Rhino command line and send us the result please?
We we’ll check it and If we don’t see anything out of the ordinary in your system information we will connect to your computer to fix it as soon as possible-
Best Regards
Juan Hernandez
sent an email- thanks
Hello Teresa,
We found the problem source, this issue only affects to Rhino 7 version and Windows 10, so it will work fine in any version of CrossGems for Rhino 8, or for Rhino 7 with Windows 11, anyway we already fix it and it will be included in the next service service release of the Rhino 7 version.
Best Regards
The CrossGems team.
