Hi @dale, i´ve found that in a plugin command (made from RhinoScript compiler) the command cannot be paused. Eg. This is similar to what is inside the compiled script:
Option Explicit
Call Main()
Sub Main()
Dim objs, str
objs = Rhino.GetObjects("Select some objects")
If IsNull(objs) Then Exit Sub
str = Rhino.GetString("Select option",, Array("Opt1", "Opt2"))
If IsNull(str) Then Exit Sub
End Sub
If i give it a command name, say “MyCommand”, i cannot do this, it ignores the _Pause command:
MyCommand _Pause Opt1
The commandline just jumps to the next string in the macro and says while still asking for objects to select
Unknown command Opt1
c…
