Paul's Rhino Utilities
Hi all! I’m an architectural designer and make a lot of scripts and utilities for Rhino as part of my workflow. I’m also legally blind (with some residual vision) and am doing some work to try to make Rhino work in a more accessible way for B/LV folks. Some of what I post here will be obviously related to that (but with some benefit to others) and some will not be as obviously access-centered, at least at first glance. But I wanted to make a thread to post different things i’ve made and am working on in case people find them useful. I will just drop things here as I make them :slight_smile:
DropToCPlane.py (1.2 KB)
There maybe be an easy way to do this that I’m overlooking, but this script allows you to drop objects to sit on the XY CPlane.
Here’s a demo of another two related AlignVertical commands. One takes the object’s top and lets you align it within the Z axis. The other does the same for the object’s bottom.
Align_VerticalTop.py (2.4 KB)
Align_VerticalBottom.py (2.4 KB)
SpaceOut.py (10.5 KB)
SpaceOut is a script that takes touching or overlapping curves or objects and allows you to space them out from each other.
Interesting post to follow
ReadCommandLine.py (5.6 KB)
This tool is my first babystep towards a screenreader native workflow in Rhino. It simply reads aloud the command line using the Windows screenreader as you model. I have it set toggle with CTRL + ALT + R
AutoPrint.py (5.1 KB)
Sometimes (a lot of the time) you just want a quick and dirty print of your drawing. This lets you print using any rectangular curve as the bounding box. Just select the curve you want, name the file, type your DPI, and select your folder location. It saves your file as both a JPEG and PDF. I initially made this to get around the print dialogue but now i use it all the time! Also the curve you use as the frame will not be in your print - it disappears during printing and reappears after.
