I am exploring with lunchbox pattern generation, more specifically hexagon cells. How do I create these hexagon cells that are equal sizes across all surfaces? Another issue I am having trouble with is how do I make sure the pattern gets “cut off” with the boundary of the shape?
Essentially creating a mullion frame with 150 thickness for this pattern.
I wouldn’t know. I always assumed ShapeMap was reserved for more complex (curved) geometry. Perhaps this would be an opportunity for me to look into how it works.
This is my solution stripped of the measures taken to rotate the grid and ensure regular hexes… and somehow made to work despite the source and target geometry sources having different orientations?.. How?
I see the two copies of Unroll Brep, once with, and once without Join = “true”. I feel like this has some part to play in it, but I still don’t understand.
In fact, it doesn’t make sense like that.
I had made the definition in Rhino7, but when I loaded the file into Rhino8 I noticed that Join doesn’t work so I left it as it was and added Deconstruct Brep.
