Hello. What is the best approach to create the pattern seen on the shoe in the image below, in a way that is ready for 3D printing?
brvdln
(Brv)
October 23, 2026, 6:30am
2
I use this to apply it to the soles with Grasshopper.
oppure puoi usare shape map
Alternatively, you can use ShapeMap. @jessesn can help you with that.
This is a group for the ShapeMap plugin: ShapeMap | Food4Rhino
[image]
About ShapeMap
ShapeMap is a plugin for Grasshopper. It integrates multiple basic functions in Rhino and has undergone secondary development. This plugin allows users to map any curve texture designed on a plane onto the surfaces of complex 3D models, while minimizing or eliminating deformation of the texture curves on the 3D surfaces. With ShapeMap, designing textures on 3D model surfaces becomes much easier, and the oper…
noise, chiedi a Brian
Alternatively, you can use Rhino’s Displacement with a Noise effect to create a texture. Ask @BrianJ
Looks very much like the Clarks Torhill Hi, btw.
geemix
October 23, 2026, 8:28pm
4
you could use pipe. for the sections use either contour on your sole or manual sections, trim the the upper part to your need and pipe with round caps.
if your sole is closed already use boolean union to create one solid. that should be printable.
eyuperdm
(Eyuperdm)
October 23, 2026, 9:21pm
5
https://www.youtube.com/watch?v=i28ktL-EOCs&t=5s I think the answer to the question is right here.
