Hi! I want to achieve a pattern on the round surface using these chips, but only angle along XY and not Z. Here’s an example of the effect I want to achieve.
Here’s my result on the round surface I want it on. As you can see, the chips angles along the surface on Z when I only want it on XY:
Knott Mönster 03.3dm (257.4 KB)
Knott Mönster.gh (25.2 KB)
I’m not sure what you want…? Maybe this?
Knott Mönster_2025Apr9a.gh (13.7 KB)
Thank you so much! This is exactly what I needed.
I might have made a mistake in the yellow group, using the average of all four vertices? Maybe it’s correct if you want if you want the fragment centered vertically on the destination frames?
I usually place such fragments at the origin to avoid any mystery about the ‘Source’ plane (Orient ‘A’ input).
There is also a component fit for purpose.
