Pattern on organic surface distorted
Hi I want to model a vent grid on an organic shape and the circle pattern starts to distort. I used UV curves to apply the pattern onto the surface. What could be a solution to keep the circle pattern everywhere?
The pattern is perfect on the top:
But distorts on the sides:
I tried to rebuild the surface with more control points but doesnt helps.
Thank you in advance!
Adam
pattern issue.3dm (790.3 KB)
Hi Adam - please post a file with the target surfaces and the pattern you’re using.
thanks,
Looks like you have a smaller grid than you need to cover all the surface. As Pascal said, a 3dm file and some boundary to show the area and direction of distribution will be very helpful.
In the FlowAlongSurface command, maybe you can try Rigid = Yes
Hi Pascal, file attached in the updated post. Thanks a lot for the help!
Thanks Miled I will check it!
Hi Rajaa, Thanks for the help I updated the file
What do you mean by that? Can you include a sketch of the desired result?
