Pattern of lines through surface
Hello! first message here! :smiley:
I’m basically modeling a tunnel, with a pattern of bolts. I’m trying to replicate this pattern through the entire tunnel section (which is a surface), separated x meters of distance (or mm, it doesn’t matter at this point).
I’ve tried with the array commands, but I haven’t had success. Any advices? I’ll post a a pic to clarify this issue a little more.
bolted tunnel.3dm (89.2 KB)
Thank you in advance, I hope you can understand that the entire tunnel needs to be bolted, separated certain distance between an array of bolts and the next one.
Hello - you want something like this:
but with known spacing, correct?
Exactly Pascal! thank you.
How do you achieve that?
Best regards
Hello - ArrayCrv - specify the spacing in the dialog:
Wow Pascal, thank you so much.
It ended up being simpler than everything I tried haha.
Have a great day, Retro.
