Pattern going from geometric to organic
Hello there!
I’m trying to create a pavement pattern going from highly geometric to somehow organic and random. At the moment I’m doing this manually… (yawn) which looks really controlled and boring:
but I dream about achieving something more along these lines:
any ideas how I might go about that?
I essentially just want the hole within the paver to be increasing in size and changing from rectangle to something rounder! :slight_smile:
ground pavers testing2.3dm (12.3 MB)
*I had to reduce my rhino file in size to attach it here, so it only shows some of pavers.
Hello
your last image looks a bit to that, but it is nice because the dual of a triangle is hexagon.
Dual of a square is a square.
Also you can go from quad to sort of hexagon using Voronoi
Here is the Voronoi version
Random move of points with magnitude depending on X (attractor logic)
Then each cell is transformed to a circle, if centers of circle are too close => merge of points
I do it 3 times, sort of Lloyd relaxation
voronoi quad to hexagons.gh (19.0 KB)
I tried with Kangaroo but without great luck
voronoi kangaroo.gh (21.5 KB)
Simple way is just MoveToPoint if you have tiles modelled. If they were from mesh you could tween them to generate smooth transition.
MoveToPoint.gh (30.2 KB)
Oh my goodness, this looks exactly what I’m after! :heart_eyes: :heart_eyes: :heart_eyes: You’re genius!! I’m just doing some experiments with it, adding additional internal offsets and surfaces, but the logic is there! Thank you so so much Laurent Delrieu , you’re life saver!
Is there a way to feed it my initial mesh/surface and tell it to make the first square paver 200mm x 200mm? At the moment I’m playing with your script and then scaling the whole thing up at the end, by 200, and do some surface subtraction to get the holes, but there must be more elegant way to achieve this! :slight_smile:
Also, I LOVE your rabbit example and how the holes gets bigger,and they go from triangles to almost circles (amazing!!):
but when I open gh sample file from that post on my machine, it just looks like this? I only woek up and started looking at it, so it’s possible that when the coffee kicks in , I will start seeying what I’m doing wrong haha
Thank you for suggestion Eddard Edr, that’s also an interesting approach! I will experiment with moving points as well.
I don’t know where is your problem or if you have one
but script dimension must be adapted to geometry
I use clipper to do the intersection. But you can use whatever you want but take care of tolerance.
voronoi quad to hexagons v2.gh (30.7 KB)
Incroyable! This is magical, thank you SO SO much Laurent!
