Hi all,
the path mapper seams to take the first branch order if more than one were flattened.
the needed order can kept if more than one path mapper were used.
example show that the numbers are horizontal counted.
Is there a way to tell the path mapper in which order the branches should be flattened?
example show that the number are vertical counted.
test to check my thoughts about the issue.
1 and 3 give the same result.
