Hi All,
I am currently trying to produce a some animations using Rhino 5. I have been successful with producing a turn-table animation, but when generating a fly through for some reason the majority of image files are blank…
When the image files are generated the first 2 frames display the object correctly, but then for the rest of the image the image is completely black.
I found that others have had a similar issue, but I couldn’t find any resolution to the problem.
[(Rhino animation and cycles)]
Image of the output files
Can anyone tell me what might be causing this?
Many thanks in advance.
