Patch - Tolerance Input Bug
Changing Distance and Internal tolerance values in Patch is fundamental screwed up.
Start Patch and the Distance tolerance and Field tolerance display initial values. (0.001 and 0.01 in the example shown):
Start typing anything in the Distance field and it immediately displays 0.0000001. Finish typing the new value, 0.1 for example, and the field continues to display 0.0000001. Changing Internal tolerance behaves the same.
Retype a new value in the Distance field and the field is correctly updated:
If the increase/decrease triangle icons are used before typing a new value in the distance field then typing the new value works correctly.
On the other hand if an attempt is made to type a new value with the 0.0000001 display resulting, and then the arrow icons are used the value increments from 0.0000001 by the original values:
Patch New Input Bug 001DC.3dm (89.6 KB)
But is in Distance and Internal tolerances. Other tolerances appear to behave correctly.
Example file for use with Patch:
SystemInfo
Rhino 9 SR0 2026-10-6 (Rhino 9 BETA, 9.0.26279.06303, Git hash:master @ 38442ba6302a687894bfeb92efd4dd088e13993d)
License type: Commercial, build 2026-10-06
License details: Cloud Zoo
Expires on: 2026-11-20
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 10.0.12
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 9-4-2026 (M-D-Y). DirectX(11)
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\ClippingBox\0.5.3\ClippingBox.rhp “ClippingBox” 0.5.3.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoAI\net8.0\RhinoAI.rhp “RhinoAI” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26279.6303
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26279.6303
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
Hi @davidcockey,
I’ve logged a ticket so a developer can investigate.
– Dale
Thanks @davidcockey for reporting.
There are 2 things going on:
  1. There is a time-out while you’re typing. If no new input is received after a short while, the value is updated. I know this sounds a bit strange, but have you tried typing faster so you can beat the time-out?
  2. The other tolerance numeric entry boxes behave the same, but you see a difference because the angle and curvature tolerances do not apply to the model, which only has distance tolerance for the G0 wire curves and the internal points. When the values do not apply, the result is not updated.
The “time-out while typing” timespan is the same across a lot of numeric entry boxes in Rhino. I’m currently not inclined to change the length of the time-out.
Update: I did some digging and the length of the time-out is an advanced setting you can change.
Go to Options > Advanced and search for TextChangingEventsDelay - you will find that it is set by default to 0.75 (seconds). Increase that value to something that works for you and your speed of typing.
@menno Thanks for the responses and explanation.
Typing fast eliminates the issue, though I’m typically a reasonable fast typist, though when entering new values I may pause for a moment to think about what value I want to use. (Touch typing using all fingers without looking at the keyboard.)
Has the use of the “time-out while typing” been expanded in Rhino 9? I couldn’t trigger it no matter how slowly I typed when entering new “Stiffness” or “Starting surface pull” values in Rhino 8 Patch, and I don’t recall encountering this situation previously.
If the use of “time-out while typing” is more widespread in V9 then it perhaps the default should be a bit longer than 0.75 seconds.
I’ll change the default.
