Hi McNeel
In the attached file, I wanted to use Patch on the center hole - in order to remove an ugly extraordinary vertex from a converted sub-d. And here’s the bug: If I run the command and then select each of the edges by hand, the result is as expected. If I instead run the command and double click an edge to select the entire ring in one go, the result is an untrimmed patch. If I pre-select the edges one by one and then run Patch, I get no result at all and if I pre-select the whole ring by double-clicking, I get another - in my eyes - wrong result. Could this be tuned up?
TIA, Jakob
patch bug.3dm (8.2 MB)
