Patch - Refine default is now On, default should be Off
Please revert to the default for the Refine option in V9 Patch being “Off”, not “On”.
BETA (9.0.26279.6303, 10/6/2026)
Patch now starts with Refine option “On”. In a previous thread @menno discussed why the default was “Off” as discussed.
I am not seeing that here, except for Untrimmed
I figured out what is happening. The example I was using has a set of four, closed edge curves so Patch opens in Trimmed mode. When I changed the input so it does not have four, closed edge curves Patch opens in Molded mode with Refine Off.
For the untrimmed mode, refinement is on by default because generating an untrimmed surface is much faster and refinement will give a continuous patch directly.
