Patch and CageEdit Macro
Hi
I normally use Patch and CageEdit commands and are usually the same each time. Can anyone educate me on how to create a Macro that would allow me to skip all the steps when used normally?
For example, for CageEdit, I always choose World, then the numeric parameters are always X8 Y16 Z4 etc etc.
For Patch, I normally use Sample = 1, U30, V 30 etc…
!_CageEdit _Pause _BoundingBox _World _X=8 _Y=16 _Z=4 _Enter _Global
!-_Patch _Pause _PointSpacing=1 _USpans=30 _VSpans=30 _Enter
http://docs.mcneel.com/rhino/6/help/en-us/index.htm#information/rhinoscripting.htm
Thank you Mahdiyar
The Cageedit macro worked nicely
The Patch macro didn’t work. Basically it says everything after !-_Patch is an unknown command.
I also don’t understand what “indent preformatted text by 4 spaces” and how it should be considered.
Is there a resource that I can refer to that may teach one to write macros? I am not sure how I would have know to type the macro out in the manner that you did.
Sorry I forgot to Add _Pause, I’ve just edited my post.
Have you checked the last link on my post?
Oh I didn’t catch that. I thought it was part of your signature. I will take a look. Thank you very much!
Yep:
https://wiki.mcneel.com/rhino/basicmacros
Thank you!
