As for now I can’t copy get to import some materials when copying from an object with the right material and material name from another document.
I tried:
_RenderPasteConflictOption
_RenderImportConflictOption
Right now if the materials with its textures already exist it is this name that is kept not the material with the new name. This becomes a nightmare if you’re trying to have contol of alot of materials and updates.
Can you provide a 3dm file with some materials and the steps to reproduce this issue please? I am not seeing an issue copy and pasting materials between separate Rhino 8 instances so I may be misunderstanding your workflow. You can use rhino3d.com/upload to send the file, say it’s for BrianJ and reference this forum post url. Also please include the text file saved from the SystemInfo command in your Rhino.
