PasteAt shortcut
In the most recent Beta, maybe the previous one, I noticed (well once I figured out what was going on) was that the Ctrl+V shortcut had been changed to the new “PasteAt,” which 4 people are going to want and makes no sense to do, but I see it’s supposed to be SHIFT+CTRL+V. It’s not, on my system anyhow.
Hi Jim -
It was decided to change the ctrl/cmd+V to PasteAt as onboarding studies have shown that new users don’t understand where pasted geometry ends up.
We’ll need to get used to hitting Enter after pasting.
But I have no idea what the basepoint it’s asking for is, so it’s impossible to actually put anything precisely anywhere? It’s optimizing for not knowing or even caring where objects go. So it’s practically useless unless you just want to randomly scatter stuff.
Is this thesis why InDesign always pastes stuff in some stupid random location? Is that a model you really want to follow?
This is insane and a clear workflow impediment. Consider my teeth gnashed.
Hi Jim -
The BasePoint is an option, not something that you need to provide. If you need to place the copy in the exact same location as where it was copied from, you hit Enter.
If you need to immediately move it elsewhere, you now have some options.
If the CopyToClipboardAt command wasn’t used to copy, the Initial and Minimal settings of the BasePoint option are the same.
Yes and?
The non-extra-Enter version of this incredibly basic command is now practically useless unless you just want to make a randomly-located copy, which you can already do much more nicely using drag+Alt.
Oh no, seriously?
This would be a big disruption to the workflow that I’ve developed - where ctrl-c and ctrl-v are mapped to thumb adjacent mouse buttons. Left hand stays on the SpaceMouse, right hand stays on the many-button-mouse, all the most frequently used commands are mapped on buttons on these devices, (i.e. copy, paste, explode, join, delete, alt-tab, ctrl-w). Reduces trips to the keyboard to a minimum.
Paste embedding spatial coordinates is kinda core functionality - esp when bouncing between several related instances of Rhino to manage a complex project where you want the parts to occur in predictable locations.
Here’s a proposal to solve that - (because sure, if you’re working on an architecture project where working space could be 360 from the view, a pasted object might land outside of any current viewport). There could be a glow or flash or a momentary floating arrow graphic on the edge of the viewport in the direction of where the pasted object landed - a UI convention to alert the user that the system responded and where to find the output.
I don’t believe.
The change is a horrible idea.
Completely different from other apps.
Introduce extra steps or clicks.
Why not…
Random thoughts:
Could the fact that from Rhino 7 onward the help documentation has erroneously stated that the keyboard shortcut for Paste is CTRL-P be a contributory factor to new users’ confusion?
Other than that, the documentation does explain that objects are pasted at the location they came from. If new users are not spotting that simple fact then, sadly perhaps, it needs greater emphasis.
Unfortunately the placement of pasted material following CTRL-V is one of the least consistent UI factors amongst Windows apps; but I don’t recall instances of modifiers to change the behaviour being part of it. I’d vote for reverting to the very basic behaviour - although I don’t qualify as I never use CTRL-V on the canvas anyway, preferring _Copy.
Regards
Jeremy
How to not make friends and irritate people (users).
Hi all!
A bit of context on why we made this change, because I think it’s important.
This came directly out of watching new users use Rhino.
A surprisingly common sequence is:
  • Create an object.
  • Select it.
  • Ctrl+C, Ctrl+V.
And yes, this really does seem to be what people do.
With the old behaviour, the copy is pasted directly on top of the original, so absolutely nothing appears to have happened.
The user then thinks “hmm, that didn’t work” and tries to select the object again.
And now, of course, there are actually two objects in exactly the same place — so Rhino immediately gives them the selection menu.
From the point of view of somebody who is just learning Rhino, that’s a pretty horrible little sequence. They’ve done something completely normal that they already understand from every other application, there’s no visible feedback that it worked, and their next click introduces them to a Rhino-specific selection menu that they weren’t expecting and don’t yet understand.
The important thing here is that the people in this thread aren’t those users :slightly_smiling_face:. You already know exactly what Paste does in Rhino, and I completely understand that some of you have workflows which depend on Ctrl+V putting an object back at exactly the same coordinates.
The good news is that if that’s your workflow, it’s very easy to restore the old behaviour.
Go to Options → Keyboard, find Ctrl+V, and change the command from:
PasteAt
back to:
Paste
That’s it — Ctrl+V will then behave exactly as it did before.
So, with that context, I’d be really interested in the feedback.
We know the old default is genuinely confusing for new users because we’ve watched it happen. On the other hand, we also know that some experienced users have good reasons for wanting the old behaviour — but they can switch it back very easily.
Does that change how you feel about which behaviour should be the default?
Thanks for that context - makes it clear how this was arrived at, and makes sense why you’d want to avoid having people go through those confusions - it exposes certain things about how Rhino’s current feedback system works, (and doesn’t) for new users lacking experience with the “inner workings”.
Here’s an alternate take -
That’s due to a deficit of graphical feedback - (which the proposed solution attempts to work around). Because the currently selected target and the resulting pasted output have the same selected highlight it’s invisible.
This is definitely the core thing.
Some UI solutions to this could look like : a new objects highlight temporarily has a 'hotter" color that rapidly fades to the standard yellow, (cooling down from the “replicator energy” effect!) - or it could be a subtle dissipating wave effect that spreads in space, or … a “puff of smoke” or a rapid blink or anything to cue the user that “Yes, don’t worry - something happened”.
(In certain view modes (like “Ghosted” you get a hint of this when there’s a slight darkening due to stacking Alpha - but it’s too subtle to expect a new user to pick up on, I use that and the Z-Fighting effect in certain renderings to tell when objects are duplicated coincidentally ))
If the above confusion is resolved this on its own isn’t terrible - the selection menu is core functionality and encountering it early is a good learning opportunity - of course it’s best if that is in a positive experience setting, rather than one of compounding confusion.
What you’re trying to solve is a very real problem - went through it myself early in Rhino and I still wouldn’t recommend the proposed solution - because it directs usability into a path that loses some very powerful aspects of how Rhino treats geometry. Using my workflow as an example again, (product design with tiny dense, intricate assemblies - many layers and obscured features and tight offsets/spacing between disparate objects) - The grid is an essential organizational tool for shuffling elements around and knowing they land back in the same spot. Would this new random paste mechanic respect the grid? And at what multiples?
Illustrator has been an environment where this random pasting is standard - it has always been a bit of an obstacle, (fortunately ctrl-shift-v overrides it there - they also have a nice feature wrt to switching between paste-in-current-layer or the sources layers).
Glad that in any event we’ll still be able to configure to the standard behavior - but it definitely feels like the proposed path destroys useful information unnecessarily and makes more work in the end and that there are other approaches to solving the root problem.
I..I can’t see the pitchforks I think it’s working!
Hi @andy
How does this effect the menu commands copy and paste?
I never use control c to copy I use the regular rhino copy commands or copy in place when I copy in rhino but…
I use the “copy command on the menu” for one thing that’s to copy something I am going to undo but want some aspect of my modeling session back. Then I copy, undo and then use paste from the menu to get my old state back with the newer copied object which places it perfectly in the correct spot.
This is a great little trick and the one good aspect of using copy and paste from the menu (ctrl-c to the menu).
I like this old behavior and don’t want it tampered with on the menu commands copy and paste.
So how will the menu commands be handled or will I have to alter the keyboard shortcut to “paste” to get the old behavior on the menu and isn’t that a bit weird that one has to alter the keyboard option to get the old behavior back on the menu commands.
Thanks for the ability to alter the command to its old behavior I’m hoping that will propagate to the menu commands as well.
Edit…
And one more further caveat is the way paste currently works in layouts.
If I need similar leaders in the same spot I copy them from a layout page and paste them into a different layout page. This way they match locations across different pages, I can then edit the leaders to say what I want since they might be different but I want them in the same location on a different page. I’d hate to see this altered as well.
RM
I just checked Copy-Pasting in Affinity; it drops the copy in the same place.
What does it say about young users? They are probably dumb.
i almost spilled my drink just give it straight facts no nonsense there​:rofl:
I mean, according to my research (trolling Reddit) at this point iPad children don’t even understand that their work is saved in a thing called a “file” in a “folder” on their computer, the care of which being their responsibility instead of just magically in the cloud somewhere attached to their Rhino account. So Rhino training at this point needs to start not so much as it does now with the concept of navigating a 3D space (they’re familiar with that!) but the very basics of operating a computer beyond the browser. Surely this could be part of that remedial training.
its going full circle isnt it?
It’s a super frustrating trend - to be fair though, it’s not entirely the youths fault. A lot of the blame goes to obfuscationist tendencies in the major OS design developments of the past decades.
There used to be a very clear and well exposed hierarchy of directories at every turn (guessing that’s how most of us here had our introductory experiences with computers). Microsoft, Google and Apple all have in their own ways made every effort to confuse this logic by creating bizarre nested loops like placing “Desktop” or “My Files” at the top of the tree, or just creating interfaces that rely purely on searching invisible databases. This convenience just obliterates any apparent structure - to where I think most non-obsessive users just cognitively surrender to never being able to understand the framework, and default to Search as the way to navigate. This robs the youngsters of a chance to observe the organizational structures and develop a sense of agency in their computer confrontations.
